2019-08-20 6:12 AM
Hello; i changed my executable file name with "Build Artifact" option. When i rebuild my project everything is fine. The executable files are generated as i wanted. But i want to change .map file name like the executable files automatically with same name. How can i do it or is it possible? I have found something at linker setting tools given at the screen shot but i can not change the label values.
Thanks.
