2023-01-07 11:29 PM
Following exceptions occur very often while using STM32CubeIDE:
Message: Unhandled event loop exception
java.lang.NullPointerException
at org.eclipse.cdt.internal.ui.buildconsole.BuildConsoleManager.lambda$1(BuildConsoleManager.java:412)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4035)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3635)
at org.eclipse.swt.widgets.Display.release(Display.java:3710)
at org.eclipse.swt.graphics.Device.dispose(Device.java:324)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:168)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
Message: Exception occurred during console property change notification.
org.eclipse.swt.SWTException: Widget is disposed
at org.eclipse.swt.SWT.error(SWT.java:4918)
at org.eclipse.swt.SWT.error(SWT.java:4833)
at org.eclipse.swt.SWT.error(SWT.java:4804)
at org.eclipse.swt.widgets.Widget.error(Widget.java:447)
at org.eclipse.swt.widgets.Widget.getDisplay(Widget.java:569)
at org.eclipse.cdt.internal.ui.buildconsole.BuildConsolePage.propertyChange(BuildConsolePage.java:253)
at org.eclipse.ui.console.AbstractConsole$PropertyNotifier.run(AbstractConsole.java:97)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.ui.console.AbstractConsole$PropertyNotifier.notify(AbstractConsole.java:112)
at org.eclipse.ui.console.AbstractConsole.firePropertyChange(AbstractConsole.java:230)
at org.eclipse.cdt.internal.ui.buildconsole.BuildConsoleStreamDecorator.setColor(BuildConsoleStreamDecorator.java:46)
at org.eclipse.cdt.internal.ui.buildconsole.BuildConsoleManager.propertyChange(BuildConsoleManager.java:362)
at org.eclipse.ui.preferences.ScopedPreferenceStore$2.run(ScopedPreferenceStore.java:325)
at org.eclipse.ui.preferences.ScopedPreferenceStore.firePropertyChangeEvent(ScopedPreferenceStore.java:322)
at org.eclipse.ui.preferences.ScopedPreferenceStore.lambda$0(ScopedPreferenceStore.java:171)
at org.eclipse.core.internal.preferences.EclipsePreferences$2.run(EclipsePreferences.java:849)
at org.eclipse.core.internal.preferences.EclipsePreferences.firePreferenceEvent(EclipsePreferences.java:852)
at org.eclipse.core.internal.preferences.EclipsePreferences.remove(EclipsePreferences.java:959)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$StylingPreferencesHandler.resetOverriddenPreferences(PartRenderingEngine.java:1448)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$StylingPreferencesHandler.resetOverriddenPreferences(PartRenderingEngine.java:1442)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$StylingPreferencesHandler.lambda$0(PartRenderingEngine.java:1431)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4243)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4235)
at org.eclipse.swt.widgets.Display.release(Display.java:3681)
Message: Problems occurred when invoking code from plug-in: "org.eclipse.ui.console".
