2023-11-13 11:45 AM
Hi, I am trying to update my STM32Cube to the latest version using Help > Check for Updates, the update fails with the following error:
Trying to update Cube V1.9.0 to the latest, running OSX 13.0. How do I fix this?
I found another thread which suggest a complete uinstall / reinstall is the solution, but I really don't want to do that as this is my main work computer and any downtime would have a huge negative impact on the projects I am working on.
Please advise.
2023-11-13 11:46 AM
This is the complete text of the error for reference:
An error occurred while collecting items to be installed
session context was:(profile=STM32CubeIDE, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Result of processing steps.
OK
OK
OK
Public key not found for 700e4f39bc05364b.
OK
OK
OK
OK
OK
OK
OK
OK
Public key not found for 70b824d9a6b4ae29.
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
OK
2023-11-13 1:29 PM
I do not EVER allow CubeIDE or CubeMX to auto update. NEVER. Instead, I install multiple versions along side each other. For production code you need a well defined and repeatable development environment. Auto-update interferes with that.
So leave your CubeIDE 1.9.0 install alone. Download and install 1.13.x into a separate directory and you will be able to run either one.
2023-11-13 2:58 PM
Seems like a good call, I will try doing it that way
2023-11-14 5:06 AM
Hello @EPala.2,
When migrating to STM32CubeIDE1.13.x please be aware of the possible migration issue
