2023-07-17 2:23 AM
Hi all,
I have a piece of code that does DMA on a UART port. This DMA i read in an buffer and i reply in 1 ms
Sometimes i dont get the incomming UART message. I wanted to confimr this with the debug mode and reading the buffer with "live expressions". But when i use debug mode with live expresions the error never occurs. The rest of the codde is the same.
Is there a difference in timing with the DMA UART when debug is enabled?
2023-07-17 3:05 AM
Mostly code order and optimization.
Would watch for appropriate use of volatile and cache coherence protocols where those may be an issue.
2023-07-17 3:05 AM
2023-07-17 3:15 AM
Thank you very much. I will do as adviced
