2025-09-09 5:39 AM - last edited on 2026-01-20 7:35 AM by Andrew Neil
i can't get to download stm32cubeide. download jus
2025-09-11 2:37 AM
To all,
the issue is now fixed. It was related to our network provider.
You can now download any software using your myST account without any problem.
Again, we apologize for the issue you may have faced.
2025-09-09 6:10 AM
STM32CubeIDE can be downloaded here. You will need to log in first.
STM32CubeIDE | Software - STMicroelectronics
If you are having issues, describe the issue you are having.
2025-09-09 9:30 AM
No, not in the Europe - website doesn't record my login attempt.
2025-09-09 10:48 AM
Seems not to be working at the moment. Try again after ST pays their hosting bills.
2025-09-10 12:48 AM
Thanks all for raising this issue. It has been raised as top priority incident and the technical team is now working to bring a solution to that shortly.
You'll get notified when this issue is fixed.
We apologize for the inconvenience.
2025-09-10 1:01 AM
Note: I succeeded with a download of CubeIDE as guest without login. Maybe this is a workaround for others as well until ST has a fix.
See https://community.st.com/t5/stm32cubeprogrammer-mcus/cannot-download-stm32cubeprog/td-p/680311
2025-09-10 1:57 AM
Yes, @mfgkw this can be a temporary workaround. It was confirmed by our technical team that the "download as a guest' flow is working fine. The issue is linked to the login flow, and they are working on it to fix that urgently.
2025-09-10 10:22 AM
Works now, at least for me.
2025-09-11 2:37 AM
To all,
2025-11-25 5:10 AM
Hello everyone,
I can't download anything. The problem with network provider may have reoccurred?
