2021-05-28 8:29 PM
Hi everyone!
I'm new to CubeIDE. I've just installed version 1.6.1 on Windows 10 and I find myself in a situation...
At my first attempt to make to blink the PC13 Led, the compiler cannot complie those lines and bring the following error:
c:\st\stm32cubeide_1.6.1\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.win32_1.5.0.202011040924\tools\arm-none-eabi\bin\ld.exe: cannot open linker script file C:\Users\NÉXTOR\STM32CubeIDE\workspace_1.6.1\Blink3\STM32F103C8TX_FLASH.ld: No such file or directory
collect2.exe: error: ld returned 1 exit status
I've already checked the following:
Those paths and exists, all if them
The STM32F103C8TX_FLASH.ld file is in the path indicated above and it's visible in the project explorer window.
I tried a couple of times and I tried in a second workspace to no avail.
Well that's it.
I wonder if you could help me with this.
Thanks in advance.
By the way, my name is Nestor and I'm from Argentina.
2021-05-29 12:02 AM
Could be due to special character usage as part of workspace path. Myself whatever tool I would avoid such. 'É' usage (part of user name 'NÉXTOR') is not recommended according to me.
Have a try with another workspace location and let us known if working
2021-05-28 11:16 PM
Could it be due to file permission issue? Please double check that the linker file permission setting allow CubeIDE to access.
2021-05-29 12:02 AM
2021-05-29 12:03 AM
Not sure about permission as linker file is only read not written as part of project build process
2021-05-29 2:17 PM
Hi Cartu38!
I've followed your indication, switched to a new workspace outside the path "with the special character" and inmediately worked fine! :grinning_face:
I'm back on track.
Thank you very much for your help! :ok_hand:
