2025-05-06 2:56 AM - last edited on 2025-05-06 3:02 AM by Andrew Neil
With an existing Cube Ide project, is it possible to change de Mpu ?
Best regards.
Sébastien
2025-05-06 3:03 AM - edited 2025-05-06 3:16 AM
change ...temperatur class T6, T7 ...on same type, same series, same case, of cpu ? yes.
migrate to type compatible other type, same pinout ? yes.
-> In Cube, pinout tab menu -> "list pinout compatible MCUs " - you can check it there.
change to ...? Other series, type , pinout ? No.
2025-05-06 3:12 AM
I edited your post title: Please try to be more descriptive with your title - Just putting "Cube_ide" isn't very informative!
@PSEBA.1 wrote:is it possible to change de Mpu ?
Are you asking about Memory Protection Unit, or a Micro Processor Unit?
Note that this is the Micro Controllers section (Cortex-M) - there is a separate section for Micro Processors (Cortex-A):
https://community.st.com/t5/stm32-mpus/ct-p/stm32-mpus
On changing target MCU:
https://community.st.com/t5/stm32cubeide-mcus/how-do-i-change-the-mcu-in-cubeide-project/td-p/174138
