STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
I am unable to debug code with enters STOP mode when the options bits are set to NOT assert reset on entering STOP mode.
With STM32CubeIDE Version: 1.0.1 Build: 3139_20190612-1256 (UTC), and an H743 Nucleo with V2J35M26, I am unable to debug code with enters STOP mode when the options bits are set to NOT assert reset on entering STOP mode. I have the registers set to k...
IAbbo.1 by Associate
  • 842 Views
Debug Start Up Script Comments and Variables
Dear allI moved from Atollic to Cube IDE.To debug a firmware without boot loader I use the Run Commands (located in the Debug Configuration -> Startup Tap) to move the $pc (program counter) to the desired address, where the firmware actually starts. ...
Extending example projects in the IDE
I'm new to IDE's (i'm old school, all my dev has been done with unix command line, shells, manually created make files), so my apologies up front for what is probably a pretty basic question. I'm starting with the example SBSFU KMS for the B-L475E-...
SBade.1 by Associate II
  • 1995 Views
