STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
I have a problem with USB working properly - USB CDC (Virtual Com Port) with CubeMX HAL after disconnecting the USB cable and connecting again.
HelloI have a problem with USB working properly - USB CDC (Virtual Com Port) with CubeMX HAL after disconnecting the USB cable and connecting again.For the test I created a project similar to the one presented here - https://www.youtube.com/watch?v=A...
Timer 8 issue in Cube IDE V1.5.0
When generating Code for STM32H753IIKx I recently stumbled across unexpected behaviour in Cube IDE V1.5.0. I'm using the processor Pins PH13-PH15 in order to output a PWM Signal from the N-Outputs of Timer 8 (CH1N1-3). However no correlating signals ...
DWeb_2 by Associate III
  • 1951 Views
Resolved! Bug in STM32CubeIDE?
Hi,I have a counter incrementing as:if (condition == TRUE) count++The counter is initialised as:int count = 0;I would expect that the counter would increment by '1' every time the condition is 'TRUE'. And this is in fact the case when I'm steppi...
NGalin by Associate II
  • 1370 Views
Adding an SPI port to an existing ST project
Hi All,I am new to the IDE Cube and I would like to know what is the most appropriate method to add an SPI to an existing Cube project ?I am specially interested in the people counter firmware running on the Nano boards, to witch I am not able to add...
TCris.1 by Associate II
  • 1885 Views
