STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
Resolved! STM32F030F4P6TR + ADC
Hello. I am new to STM32F030F4P6TR programming, so I am asking for your help. You need to write a simple program to light up the LEDs depending on the voltage. But I have some problems with the ADC. To begin with, I wrote a simple program that flashe...
Need Support regarding Drivers of STM32 F401 board.
Hello Everyone,I wrote the code by self for GPIO drivers , as a step by step process i am adding code for other peripherals & buses after taking due time in learning , the code progress as of now (as per my knowledge) should be enough to enable the G...
How to customize a STM32CubeIDE code generator for my board?
It's been quite a while since I started to work on various MCUs with STM32CubeIDE.As it was quite magical at the start, now I roughly understand how a project is configured, especially what files are needed for what, where are they located, how they ...
HTD by Senior III
  • 7091 Views
STM32H750 CubeIde MPU setting ignored
Hello, I am trying to get Ethernet working, I don't like HAL, switched all is possible to LL library. @Piranha​ Hi, if this is a bug please add to your report if someone try use LL configuring Ethernet. Platform LinuxCUBEIDE Version: 1.7.0STM32Cube_F...
RRoma.4 by Associate II
  • 3064 Views
Code performance profiling
Hello,Is there an integrated tool in STM32CubeIDE that I can use to measure how long a block of code lasts?I was used to use a similar tool on TI CodeComposer, that measured the elapsed clocks from a breakpoint to another.Thank you,Carlo
CTabo.1 by Senior
  • 4947 Views
Resolved! error: unknown type name '__root'
I am using below codes. But this define not supportted #define KeepInCompilation __root #define KeepInCompilation __root   /* Private function prototypes -----------------------------------------------*/ int Init (); KeepInCompilation int Write (uin...
Target is not responding, retrying.. Issues ?
Hai.....,I am using STM32H743IIT6 custom Board and CubeIDE. Run the code after download it showing "Target not responding retrying......." and again try to download the same code in MCU i couldn't download, It show "Error in initializing ST-LINK de...
GMano.1 by Associate II
  • 22029 Views
