STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
"stm32cubeidec -build all" results to extra build runs
I have tried to build an example STM32H7Cube project with a command line script (attached) and got that the each CM7 and CM4 project configuration is built twice: the "Release" for CM7 is built twice, then the "Debug" for CM7 is built twice, and then...
ERROR by Senior
  • 998 Views
Resolved! TIM2 as a sequencer for TIM5, TIM1 and TIM8
Part: STM32L4R5ZIT6I would like to use TIM2 to increment 3 other timers at different times:TIM2 is incrementing from an external clock and rolling over at a set period.1. TIM2 rollover would increment TIM52. TIM2 Compare 1 would increment TIM13. TIM2...
RChap.1 by Associate III
  • 3287 Views
Resolved! Cube IDE 1.15.1 Freeze when creating example project
Hi, I am trying to create an example project for my NUCLEO-F401RE board by following the following steps:1. Completely clean Debian 11.9.0 installation (in virtual machine)2. Download and install STM32CubeIDE 1.15.1 (STM32CubeIDE-DEB)3. Launch the ID...
FJons.1 by Associate II
  • 6440 Views
Resolved! Installation of SonarLint fails
When I try to install SonarLint from Eclipsemarkete place I get the following errorUnable to read repository at https://eclipse-uc.sonarlint.org/content.xml. Certificate chain is not validSTM32cubeIDE 1.7.0 on WindowsI asked the question on the Sonar...
Stefan1 by Associate III
  • 3465 Views
Resolved! Update STM32CubeIDE to specific version
One of my machines is running 1.14.1. My customer is at 15.0 and does not wish to change to 15.1 this close to deployment. Is there any way to update the IDE to 15.0? If I select 'Update' from the 'Installation Details' from the 'About' screen I only...
jlag by Associate III
  • 2418 Views
Cubeide download program without erase full chip
Hello,My name is Ray.I'm an end user that come from Taiwan,I'm still learning coding with stm32Recently​ i encounter a problem about debug via STMCubeIDE,The version is 1.15.1Once i coding fine and process into debug mode,it will perform a full chip ...
stm32c0116-dk & openocd
Hi,I tried to connect my stm32c0 board to openocd to work in CLion but found that latest open ocd version doesn't support it. I found ST version of OpenOCD and build it but inside it I still can't find stm32c0 board configuration.So my question is ho...
Ubxlib
Hello everybody.Has anyone worked with the ubxlib from ublox?Thank you for your attention.
tEaM7 by Associate
  • 1450 Views
Could not download IDE
Hello I am currently logged in to st.com and attempted the download but failed.It did not show any sign of error, but it keeps going back to initial page.Is there any issue with the download now?I am attempting on windows 11 pro 22631 build via lates...
godSSom by Associate
  • 1084 Views
