STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
  • 1703 Views
STM32CubeCLT 1.21.0 released
  • 638 Views
ST Cube Ide bad ELF programming from debugger.
Good morning,we have a problem with ELF file loading. We are using an STM32U575 MCU on a Nucleo board.In particular:the location 0x0802A61B in the ELF file is set at 0x00 (we see it by open the ELF file with Cube Programmer).1) If we load the ELF fil...
SafeDev by Associate II
  • 1288 Views
Resolved! Retarget scanf on STM32G070RBxx Cortex M0+
(originally a reply to https://community.st.com/t5/stm32cubeide-mcus/retarget-printf-on-stm32g070rbxx-cortex-m0/td-p/720883) Hi @Andrew Neil,For the scanf do we need to make any other change?My read function is-  int _read(int fd, char *ptr, int len)...
AVerm.4 by Associate III
  • 4387 Views
  • 4 kudos
Resolved! STM32L552 Breakpoints won't work
Hi, I just got my board STM32L552 and currently am setting up development environment for it. I'm testing the board with an example project 'CORTEXM_InterruptSwitch_TrustZone' and the code works well, however, I'm not able to set breakpoints for debu...
How to run code and view serial on Nucleo board
Hello,I am trying to count how many clock cycles pieces of code take to run on my Nucleo board. I am using the following code for timing: start_cycles = DWT->CYCCNT; // dummy code end_cycles = DWT->CYCCNT; diff_cycles = end_cycles - start_cycles; pri...
