2025-11-04 5:38 PM
I'm not used to the automatic code completion feature at present. For example, the "for" code block is written as "for (init-statement; condition; inc-expression) {}". Could it be modified to have the code block written as "for (int i=0; i<size; i++) {}"? This would be much more convenient. Do you have such a configuration?
2025-11-05 1:03 AM
Hi @t_j_l
Thanks for the feedback we will try to add such snippet automatically in our extension, otherwise to have this in the code auto completion you have to add a snippet, please follow these steps:
1- open command palette by CTRL+shift+P
2- search for menu "snippets: configure snippets" and name your snippet file
3- add this snippet (you can change the prefix and description as you want
