2022-10-07 1:23 AM
We're using Ecosystem 2.1.0 still (I know!).
I'm using the CubeMX autogen code i.e.
rcc_pins_mx: rcc_mx-0 {
u-boot,dm-pre-reloc;
pins1 {
pinmux = <STM32_PINMUX('G', 2, AF1)>; /* RCC_MCO_2 */
bias-disable;
drive-push-pull;
slew-rate = <1>;
pins2 {
pinmux = <STM32_PINMUX('I', 11, AF0)>; /* RCC_MCO_1 */
bias-disable;
drive-push-pull;
slew-rate = <0>;
rcc_sleep_pins_mx: rcc_sleep_mx-0 {
pins {
pinmux = <STM32_PINMUX('G', 2, ANALOG)>, /* RCC_MCO_2 */
<STM32_PINMUX('I', 11, ANALOG)>; /* RCC_MCO_1 */
If this is in U-Boot's devicetree, U-Boot locks up with no message on start-up.
If I take it out of U-Boot's devicetree but leave it in the kernel's, U-Boot starts up fine but the kernel locks up, again with no panic or other output.
2022-10-27 9:02 AM
Hi @Spamfast ,
I guess you are facing a known issue while configuring MCO pin on MP15 with release < 4.0
Please have a look to post
And let me know if it help !
Olivier
2022-11-16 5:02 AM
HI @Spamfast
did you progress on your issue ?
Regards,
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
