How is SUB_NRST generated in STM32MP157x-EV1 eval board?
Grodriguez
Senior
According to the documentation of the EV1 eval board:
"The STM32MP157xAA3 also drives a sub system reset, SUB_NRST signal on PD10 IO, to the peripherals: USB Host Hub, MFX, Ethernet, and RGB_LTDC connector."
Is this signal generated automatically by the STM32MP157? Is it software controlled? If the latter, is this implemented in OpenSTLinux images by default?
Thanks,
Guillermo
1 ACCEPTED SOLUTION
Accepted Solutions
mleo
Senior II
Hi Guillermo
The SUB_NRST signal is software controlled. But there's no default implementation in OpenSTLinux.
BR,
Milan
2 REPLIES 2
mleo
Senior II
Hi Guillermo
BR,
Milan
Clear, thank you!
