2023-05-08 2:00 AM
my situation is this:
We want to use a "liveSD" image and boot from emmc by default if "liveSD" isn't found.
The SD card should be inserted even if it is not a "liveSD" card, boot eMMC should be running.
I know we could override the OTP boot sequence, but can BootROM detect this from the "partition table" or device?
2023-05-12 6:57 AM
Hi @Community member
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Regards,
Billy
2023-05-12 6:57 AM
Regards,
Billy
