2022-05-31 1:34 AM
We are using OpenSTLinux as base distro for configuring and developing product on a custom STM32MP1 based embedded board. We plan to develop some testing and validation plans for the same. Just wanted to understand what sort of testing is carried out for the OpenSTLinux to ensure the stability? How can we request access to those if needed?
2022-06-01 7:32 AM
Hi @NPal.2 ,
Can you please elaborate further your expectation?
Is your need is about a test infrastructure or about some test cases ?
What do you mean by stability ? Reliability ? Robustness ?
Under nominal condition or to some limit ?
Etc ..
Olivier
2022-06-01 11:14 PM
HI @Community member Thanks for the quick response on this. I am more looking for data around how OpenSTLinux was tested for stability ? What kind of testing was performed since a lot things are packed together making a custom linux altogether.
My understanding regarding the stability , reliability etc under normal conditions would be that , core kernel modules (MM, Scheduler etc) are working flawlessly and there are no abrupt system crashes or hang state.
