2021-11-03 7:38 AM
Hi, in custom_app.c file, my event WRITE_NO_RESP_EVT is not call in the function Custom_STM_App_Notification. Where are the BLE notification in custom app ?
2022-03-31 4:05 AM
Hi, I have got the same problem. WRITE_NO_RESP_EVT in custom_app.c is never called.
Did you find a solution for the problem?
2022-04-04 7:53 AM
Yes, i have modify the Custom_STM_Event_Handler function
static SVCCTL_EvtAckStatus_t Custom_STM_Event_Handler(void *Event)
SVCCTL_EvtAckStatus_t return_value;
hci_event_pckt *event_pckt;
evt_blecore_aci *blecore_evt;
aci_gatt_attribute_modified_event_rp0 *attribute_modified;
aci_gatt_read_permit_req_event_rp0 *read_req;
Custom_STM_App_Notification_evt_t Notification;
/* USER CODE BEGIN Custom_STM_Event_Handler_1 */
/* USER CODE END Custom_STM_Event_Handler_1 */
return_value = SVCCTL_EvtNotAck;
event_pckt = (hci_event_pckt *)(((hci_uart_pckt*)Event)->data);
switch(event_pckt->evt)
case HCI_VENDOR_SPECIFIC_DEBUG_EVT_CODE:
blecore_evt = (evt_blecore_aci*)event_pckt->data;
switch(blecore_evt->ecode)
case ACI_GATT_ATTRIBUTE_MODIFIED_VSEVT_CODE:
/* USER CODE BEGIN EVT_BLUE_GATT_ATTRIBUTE_MODIFIED_BEGIN */
/* USER CODE END EVT_BLUE_GATT_ATTRIBUTE_MODIFIED_BEGIN */
attribute_modified = (aci_gatt_attribute_modified_event_rp0*)blecore_evt->data;
if(attribute_modified->Attr_Handle == (CustomContext.CustomUart_TxHdle + CHARACTERISTIC_DESCRIPTOR_ATTRIBUTE_OFFSET))
return_value = SVCCTL_EvtAckFlowEnable;
/* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1 */
/* USER CODE END CUSTOM_STM_Service_1_Char_1 */
switch(attribute_modified->Attr_Data[0])
/* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1_attribute_modified */
/* USER CODE END CUSTOM_STM_Service_1_Char_1_attribute_modified */
/* Disabled Notification management */
case (!(COMSVC_Notification)):
/* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1_Disabled_BEGIN */
/* USER CODE END CUSTOM_STM_Service_1_Char_1_Disabled_BEGIN */
Notification.Custom_Evt_Opcode = CUSTOM_STM_UART_TX_NOTIFY_DISABLED_EVT;
Custom_STM_App_Notification(&Notification);
/* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1_Disabled_END */
/* USER CODE END CUSTOM_STM_Service_1_Char_1_Disabled_END */
break;
/* Enabled Notification management */
case COMSVC_Notification:
/* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1_COMSVC_Notification_BEGIN */
/* USER CODE END CUSTOM_STM_Service_1_Char_1_COMSVC_Notification_BEGIN */
Notification.Custom_Evt_Opcode = CUSTOM_STM_UART_TX_NOTIFY_ENABLED_EVT;
/* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1_COMSVC_Notification_END */
/* USER CODE END CUSTOM_STM_Service_1_Char_1_COMSVC_Notification_END */
break;
default:
/* USER CODE BEGIN CUSTOM_STM_Service_1_Char_1_default */
/* USER CODE END CUSTOM_STM_Service_1_Char_1_default */
break;
} /* if(attribute_modified->Attr_Handle == (CustomContext.CustomUart_TxHdle + CHARACTERISTIC_DESCRIPTOR_ATTRIBUTE_OFFSET))*/
else if(attribute_modified->Attr_Handle == (CustomContext.CustomUart_RxHdle + CHARACTERISTIC_VALUE_ATTRIBUTE_OFFSET))
/* USER CODE BEGIN CUSTOM_STM_Service_1_Char_2_ACI_GATT_ATTRIBUTE_MODIFIED_VSEVT_CODE */
Notification.Custom_Evt_Opcode = CUSTOM_STM_UART_RX_WRITE_NO_RESP_EVT;
Notification.DataTransfered.Length=attribute_modified->Attr_Data_Length;
Notification.DataTransfered.pPayload=attribute_modified->Attr_Data;
/* USER CODE END CUSTOM_STM_Service_1_Char_2_ACI_GATT_ATTRIBUTE_MODIFIED_VSEVT_CODE */
} /* if(attribute_modified->Attr_Handle == (CustomContext.CustomUart_RxHdle + CHARACTERISTIC_VALUE_ATTRIBUTE_OFFSET))*/
/* USER CODE BEGIN EVT_BLUE_GATT_ATTRIBUTE_MODIFIED_END */
/* USER CODE END EVT_BLUE_GATT_ATTRIBUTE_MODIFIED_END */
break;
case ACI_GATT_READ_PERMIT_REQ_VSEVT_CODE :
/* USER CODE BEGIN EVT_BLUE_GATT_READ_PERMIT_REQ_BEGIN */
/* USER CODE END EVT_BLUE_GATT_READ_PERMIT_REQ_BEGIN */
read_req = (aci_gatt_read_permit_req_event_rp0*)blecore_evt->data;
if(read_req->Attribute_Handle == (CustomContext.CustomBatHdle + CHARACTERISTIC_VALUE_ATTRIBUTE_OFFSET))
/*USER CODE BEGIN CUSTOM_STM_Service_2_Char_1_ACI_GATT_READ_PERMIT_REQ_VSEVT_CODE_1 */
/*USER CODE END CUSTOM_STM_Service_2_Char_1_ACI_GATT_READ_PERMIT_REQ_VSEVT_CODE_1*/
aci_gatt_allow_read(read_req->Connection_Handle);
/*USER CODE BEGIN CUSTOM_STM_Service_2_Char_1_ACI_GATT_READ_PERMIT_REQ_VSEVT_CODE_2 */
/*USER CODE END CUSTOM_STM_Service_2_Char_1_ACI_GATT_READ_PERMIT_REQ_VSEVT_CODE_2*/
} /* if(read_req->Attribute_Handle == (CustomContext.CustomBatHdle + CHARACTERISTIC_VALUE_ATTRIBUTE_OFFSET))*/
/* USER CODE BEGIN EVT_BLUE_GATT_READ_PERMIT_REQ_END */
/* USER CODE END EVT_BLUE_GATT_READ_PERMIT_REQ_END */
break;
case ACI_GATT_WRITE_PERMIT_REQ_VSEVT_CODE:
/* USER CODE BEGIN EVT_BLUE_GATT_WRITE_PERMIT_REQ_BEGIN */
/* USER CODE END EVT_BLUE_GATT_WRITE_PERMIT_REQ_BEGIN */
/* USER CODE BEGIN EVT_BLUE_GATT_WRITE_PERMIT_REQ_END */
/* USER CODE END EVT_BLUE_GATT_WRITE_PERMIT_REQ_END */
break;
/* USER CODE BEGIN BLECORE_EVT */
/* USER CODE END BLECORE_EVT */
default:
/* USER CODE BEGIN EVT_DEFAULT */
/* USER CODE END EVT_DEFAULT */
break;
/* USER CODE BEGIN EVT_VENDOR*/
/* USER CODE END EVT_VENDOR*/
break; /* HCI_VENDOR_SPECIFIC_DEBUG_EVT_CODE */
/* USER CODE BEGIN EVENT_PCKT_CASES*/
/* USER CODE END EVENT_PCKT_CASES*/
default:
/* USER CODE BEGIN EVENT_PCKT*/
/* USER CODE END EVENT_PCKT*/
break;
/* USER CODE BEGIN Custom_STM_Event_Handler_2 */
/* USER CODE END Custom_STM_Event_Handler_2 */
return(return_value);
}/* end Custom_STM_Event_Handler */
2022-04-04 11:20 PM
Thanks a lot, it works!
