Re: How to solve "Error: No STM32 target found!" using Nucleo-WB0?
mpj1
Associate
I have NUCLEO-WB05K/NUCLEO-WB07CC/NUCLEO-WB09KE only the NUCLEO-WB09KE can be connected to with Software Reset mode.
The NUCLEO-WB05K/NUCLEO-WB07CC boards have the above error on connect.
The Hardware Reset mode doesn't work with the NUCLEO-WB09KE (or the other boards).
All STLink firmware up to date - not many jumper options to get wrong on these boards.
Windows 11.
1 ACCEPTED SOLUTION
Accepted Solutions
Imen.D
Hello @mpj1
You might have encountered the issue described in this article:
Establishing the initial connection with NUCLEO-WB05KZ, 7CC, and 9KE boards
So, try entering bootloader mode using the correct jumper settings to recover the boards.
When your question is answered, please close this topic by clicking "Accept as Solution".
Thanks
Imen
2 REPLIES 2
Imen.D
Hello @mpj1
Thanks
Imen
mpj1
Associate
Setting the JP1 to BOOTLoader and and connection mode to Normal/Hot plug I've manage to connect by holding the reset button and connecting as soon as I can when releasing the reset button.....
