2024-11-14 10:39 PM
Using the Zigbee stack as a coordinator, is there a callback available to notify when a new device is associated in the network?
We observe the following in the M0 log:
[M0] [00000015.076][PLATFORM] nwk_handle_assoc : Association accepted, sending response (0xb0dc, 0xa4c1383054f9cec1)
We can detect the new device in the ZB_NWK_NIB_ID_NeighborTable, but having a callback to trigger on association would be very helpful. I've checked the documentation and examples but haven’t found any information on this.
Thank you!
2024-11-15 3:55 AM
Hi @Joan Duran,
You can use ZbMsgFilterRegister API at the startup (inside the func APP_ZIGBEE_StackLayersInit) to register the callback you want to use to retrieve any network status change.
Please find below an example to detect a new device join :
ZbMsgFilterRegister( stZigbeeAppInfo.pstZigbee, ZB_MSG_FILTER_JOIN_IND, ZB_MSG_DEFAULT_PRIO, APP_ZIGBEE_DeviceJointCallback, NULL );
static enum zb_msg_filter_rc APP_ZIGBEE_DeviceJointCallback( struct ZigBeeT * zb, uint32_t lId, void * pMessage, void * arg )
struct ZbNlmeJoinIndT * pstJoinMessage;
if ( lId == ZB_MSG_FILTER_JOIN_IND )
pstJoinMessage = ( struct ZbNlmeJoinIndT * )pMessage;
switch ( pstJoinMessage->rejoinNetwork )
case ZB_NWK_REJOIN_TYPE_ASSOC :
case ZB_NWK_REJOIN_TYPE_ORPHAN :
case ZB_NWK_REJOIN_TYPE_NWKREJOIN :
case ZB_NWK_REJOIN_TYPE_NWKCOMMISS_JOIN :
case ZB_NWK_REJOIN_TYPE_NWKCOMMISS_REJOIN :
/* A new Device has Join Network at MAC/NWK level */
APP_ZIGBEE_SetNewDevice( pstJoinMessage->nwkAddr, pstJoinMessage->extAddr, pstJoinMessage->capabilityInfo );
break;
default :
break;
return( ZB_MSG_CONTINUE );
Best regards,
Ouadi
2024-11-14 11:45 PM
Use the emberIncomingMessageHandler() callback to listen for ZDO_Device_Announce messages. Or you can also use emberAfPluginNetworkSteeringDeviceJoinedCallback() (if using the Network Steering plugin) to detect when a device has joined.
2024-11-15 3:55 AM
Hi @Joan Duran,
break;
default :
break;
Best regards,
Ouadi
