2023-01-09 8:37 PM
I'm working on transmitting audio over BLE. I have successfully connected SPH0645 mic using I2S and also I have connected speakers for the output. The thing is I don't know how to transmit audio over BLE. I tried creating custom template to notify the audio value buffer. Can anyone help me with this. Thanks in advance.
2023-01-10 12:40 AM
transmit audio over BLE to where? android/windows/....
Does your receiver side have (hardware)BLE5.0 at least?
Here you have the theory, you broadcast the audio stream.
2023-01-10 1:07 AM
Hi Javier,
I'm transmitting to my laptop. Using python I receive packets in a bytearray. Then I convert those to audio file (.wav).
I managed to notify the data but the data what I'm getting is not the data what I'm sending.
2023-01-18 12:27 AM
You can look FP-AUD-BVLINKWB1 function pack which allows to perform full-duplex voice streaming or stereo music streaming over BLE using the advanced Opus compression algorithm.
Best Regards
2023-01-18 1:01 AM
Are you sure this is fast enough?
2023-01-18 1:02 AM
@LR.2 https://pypi.org/project/opuslib/
