2022-04-08 7:53 PM
I chose Lora E5 Mini to get a sensor measurement. For my application, I do not need a gateway and connection to a server like thingspeak. I want to make two end devices communicate. I configured the device in ABP mode, set the Tx and Rx frequency and Data rate as shown in the screenshots. But I am not able to make them communicate.
2022-04-09 3:43 AM
Looking to use LoRaWAN or P2P ?
2022-04-09 3:48 AM
Thank you for your response.
I'm looking to use P2P.
2022-04-09 5:57 AM
You should look at the PingPong example
https://www.st.com/en/partner-products-and-services/lora-e5-mini-dev-board.html
2022-06-18 12:17 PM
@MN.6 Hi MN.6,
i am facing same problem as of yours.If you have solved it can you please help me out with p2p communication.
2022-06-18 12:19 PM
if possible please reach out to me on 1411prasang@gmail.com
