2019-09-07 7:05 PM
2019-09-09 4:35 AM
It should be possible using the HCI_LE_SET_ADVERTISING_PARAMETERS command that enables the selection of the advertising channel map ( Advertising_Channel_Map parameter). Note that this call must be done before the GAP command that triggers the scanning.
2019-10-19 5:28 PM
Thanks Remi
I asked about one channel scanning ability - not about one channel advertising ability.
2019-10-22 8:13 AM
We are not aware of any BLE command enabling the possibility to scan only 1 single channel.
At least this is not supported with our BLE stack.
