STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4119 Views
send a simple message like "hello" with lorawan cube to TTN
Hello ,I use this demo board B-L072Z-LRWAN1 with the soft End Node I-CUBE-LRWAN 1.2.0But I do not understand why I cant send the messagei disable all senser and i try to send with " LORA_send( &AppData, LORAWAN_DEFAULT_CONFIRM_MSG_STATE); "in static ...
ahmed1 by Associate
  • 1707 Views
i-cube-lrwan end-node example and ttn integration
I've trying to establish a bi direction communication b/w my end-node STM32L073RZ and SX1276 and TTN. I have successfully transmitted sensor data from my end node but have no luck in receiving from TTN. I have tried changing Rx window delay, window t...
ASing.8 by Associate
  • 12715 Views
Only activation messages are showing in ttn application but in gateway we are able to see join,up-link messages.this happens only when i use OTAA.In ABP it works fine.I am using Lora Stack provided by STMicroelectronics.
Only activation messages are showing in ttn application but in gateway we are able to see join,up-link messages.this happens only when i use OTAA.In ABP it works fine.I am using Lora Stack provided by STMicroelectronics.Gateway=Laird SentriusEnd Devi...
BGowd.3 by Associate II
  • 665 Views
STM32WB55VG availability
This part is not available in any retail market (like Digikey, Mouser,....) How should we get the samples? We are planning to use in our NPI, kindly help.
JK.9 by Associate
  • 1207 Views
No LoRa received message from the backend
Posted on October 11, 2017 at 11:08Hi everybody,I am working with the evaluation board B-L072Z-LRWAN1 with I-CUBE-LRWAN embedded software. I am trying to customize the received frame from the LoRaWAN network. I am working in France 868 MHz with the ...
