STM32 MCUs Wireless
ctrois by ST Employee
  • 301 Views
Ouadi by ST Employee
  • 4118 Views
stm32wb55 reset pin
Hello!It will be interesting to know about reset system inside stm32wb55. I have got not casual reset schematic.Where InA is digital Isolators IC input. I also tested without this IC and result is the same. Rpu is build-in stm32wb55 pull up resistor....
[STM32WLE5] RX buffer
Hi!Basing on Ping-Pong example code from CubeIDE I made fw to test WMBUS protocol.Generally works good, but I have some issues:After transmitting data the size of RX buffer is set to size of last transmitted packet. So after transmission of short pac...
olek by Associate
  • 1054 Views
