2025-09-18 8:46 PM
I want to add a custom BLE service in STM32CubeMX. I saw on a website that the Add Custom Service feature could be used for this. However, I don't know the procedure for adding a service using this feature. Please tell me the steps to add a service using the Add Custom Service feature in the latest IDE and MX environment.
2025-09-19 9:27 AM
Hello @TYAMA.2
On the BLE Applications and Services tab, you have to select the number of services you want to implement. Once this is done, N new tab will be added to your configuration view (N is the number of services you selected):
On each of the new tab you can configure the service you are looking for:
Best Regards.
STTwo-32
2025-09-18 9:26 PM
2025-09-19 9:27 AM
Hello @TYAMA.2
Best Regards.
STTwo-32
2025-09-21 9:07 PM
Thank you for your reply.
I understand that the normal way to add services is "Number of services".
Thank you.
2025-09-21 10:28 PM
Since your question is answered. Please accept the comment that answer your question as solution to close this post.
Best Regards.
STTwo-32
