2025-07-15 11:16 AM
We are using TouchGFX for LCD UI design. It seems that the generated c files for image have reverse-ordered 16-bit data. We have to revert the image at run-time. Is there a way to revert the 16-bit order during image converting?
2025-08-20 5:55 AM
Hello Izlin,
By reverse, you mean little/big endian ? If so, no there's no way to switch edianess.
What is your use case ?
BR,
Louis B.
