2020-11-01 7:54 AM
When to add speedometer and pointer apps to touchgfx app
can you look at the link
https://www.syncfusion.com/blogs/post/speedometer-using-flutter-radial-gauge.aspx/amp
2020-11-01 8:42 AM
How is your question?
2020-11-02 12:06 AM
If you're asking how to ask add something like a speedometer, please check out the clock example from TouchGFX designer. You can just adapt it to show only one hand and modify the ranges and values to be that of a speedometer - That's pretty much what you want i think.
/Martin
