Simulator exits prematurely
Hello, if I create a partial project from CubeMX, open it in TouchGFX designer, add a button and run the simulator, nothing happens. The simulator executable is built correctly, but it exits immediately with no errors reported.
15 REPLIES 15
Martin KJELDSEN
Chief III
Screenshots and logs please :)
Where are the logs located? There's nothing to take a screenshot of.
Martin KJELDSEN
Chief III
%APPDATA%/TouchGFX-4.13.0
Does the designer tell you that an error occured ?
The Windows Event Log indicates:-
Faulting application name: simulator.exe, version: 0.0.0.0, time stamp: 0x5ef0b0dc
Faulting module name: dgapi.dll, version: 7.5.2.54, time stamp: 0x5d7fb4a8
Exception code: 0xc0000005
Fault offset: 0x00030cad
Faulting process id: 0x7f10
Faulting application start time: 0x01d648985da4ed13
Faulting application path: Src\build\bin\simulator.exe
Faulting module path: c:\windows\system32\dgapi.dll
Report Id: c5223111-826e-469d-9052-a9de149abf38
Faulting package full name:
Faulting package-relative application ID:
Martin KJELDSEN
Chief III
Windows version?
Windows 10. No error reported by designer. The log suggests a problem downloading a package. Is there a way to specify proxy server configuration?
Martin KJELDSEN
Chief III
I've never seen this issue before but i'm seeing a lot of activity on various sites about generally faulting dgapi.dll in Windows.
Martin KJELDSEN
Chief III
Designer uses the system proxy information, and that may be a blocker for downloading packages - BUT, it should not be a problem here if you're already at the compiling stage. You could try running the simulator outside of the designer.
Go to the application folder from a TouchGFX Environment and type
make -f simulator/gcc/Makefile
./build/bin/simulator.exe
See if you get the same error.
The simulator runs fine on my personal laptop which does not have dgapi.dll. This is on all our corporate machines and cannot be removed - is there any way around it?
Building outside Designer is not working:-
make.exe -f simulator/gcc/Makefile
process_begin: CreateProcess(NULL, ruby ../Middlewares/ST/touchgfx/framework/tools/textconvert/main.rb assets/texts/texts.xlsx ../Middlewares/ST/touchgfx/framework/tools/fontconvert/build/win/fontconvert.out generated/fonts generated/texts assets/fonts ., ...) failed.
make (e=2): The system cannot find the file specified.
generated/simulator/gcc/Makefile:219: recipe for target 'texts' failed
make[1]: *** [texts] Error 2
simulator/gcc/Makefile:32: recipe for target 'all' failed
make: *** [all] Error 2
