2025-05-02 1:26 PM
Does anyone have an improved example to understand the MVP[1] (and widget/containers),
where you change the base implementation of the MVP ?
I was able to defined default implementation for the Model and the View but not for the Presenter or Drawables.
class ModelListener
public:
virtual char* getPAmessage(eVerbose_t type) { return model->PAmessage; }
class View : public Screen
public:
char* getPAmessage(eVerbose_t type) { return presenter->getPAmessage(type); }
The goal was to make a signal that is understood by every layer without having to use boilerplate at each new implementation of these interfaces.
[1] Example: "Understanding Application Structure"
2025-05-04 11:38 PM
Hello @Marc_LM,
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Best regards,
Maxime
