2024-09-23 4:54 AM
I have a custom board with STM32H743 and working on a project by TouchGFX 4.24. When the device power on or reset, some times I have a mixed image including numbers, pictures and ..., which I attached the image... and some times every thing is Ok after reset or power on. I have another project by TouchGFX on this board, which it always works fine.
Please help me with this, thanks.
2024-09-23 8:50 AM
I don't get what's your mean by make diff, The projects are different...
2024-09-23 8:51 AM
Start by checking the MPU configuration.
It's not obvious to tell you what is the problem. As you have a working project, you need to check what is the difference between your working and non-working projects.
2024-09-23 9:01 AM
I have been checking 2 project together but no special differences I have found, Could importing GUI to this project be related to the problem?
2024-09-24 4:02 AM
It's hard to tell... You can start the project from scratch and proceed step by step and try to find when the behavior occurs to locate the issue.
