2019-01-09 10:41 PM
Hello everyone.
I want to use only CPU to read and process VGA image with YUV format from camera. It's mean we have 640*480*2 = 600kbytes each frame and this is more than the 500 kbytes memory of CPU that I use. (I want to transfer directly data from DCMI to CPU by DMA without using any other RAM.)
So I think is it possible if first step I read the first half data, process it and the second step for the remain data?
But I don't know this ideal is posible or the right way to change the DMA configure? It's really complicated for me.
Many thanks for any helpp!!!!
2019-01-10 12:13 AM
No, the data have to be stored somewhere.
If the picture is absolutely stationary, you might perhaps try to experiment with taking first part of one frame and second part of a later frame, but depending you how exactly do you process the data the results may be unsatisfactory.
2019-01-10 12:40 AM
Hi JW. Thanks for your comment.
I had tried by configure the window size but It just efficient after whole data transfered from DCMI to CPU. So I think configure window with small size does not mean transfer data is smaller.
Then I reduce the length data of DMA configure by VGA length/2, I got the first half of data. But unknow how to get the second half.
I think I have to spend more time to search about prosess the data again. Thanks so much.
