2019-08-15 6:25 AM
Is it possible to assign the text alignment (left, center, right) through code? If yes, how?
2019-08-15 12:02 PM
Hi @Iswarya,
That's not possible i'm affraid. You specify the alignment through the text sheet alone.
/Martin
2019-08-15 12:02 PM
Hi @Iswarya,
/Martin
2019-08-15 5:03 PM
Hi @Martin KJELDSEN ,
Can't be changed it by editing "TypedTextDatabase" file?
Youssef
2019-08-19 4:56 AM
@youssef.amimi,
Yes, you can do that (in a way) :) But this value also comes from the text-sheet. When you re-generate your assets this file would get overwritten, and you'd have to compile the application every time you change it.
/Martin
