Intermediately TouchGFX evaluation watermark is shown on screen,How to remove this watermark?
ABhan
Associate II
In my case,intermediately TouchGFX evaluation watermark is shown on screen.And i have programmed application for STM32L4R5 board.
Are we need to obtain a licensed version of the TouchGFX library.
If this is the case then,How to obtain a licensed version of the TouchGFX library?
4 REPLIES 4
Martin KJELDSEN
Chief III
Hi @ABhan​,
Since 4.10.0 there is no longer any watermark. Instead, TouchGFX is locked to STM32. No licenses required!
Hope that helps,
Best regards,
Martin
ABhan
Associate II
Thank you Martin.
Then Why my application showing watermark on STM32L4R5 nuclio board application?
Martin KJELDSEN
Chief III
Hi Atul,
Which version of TouchGFX are you running? If you downloaded 4.10.0 from the ST website the watermark should not be there.
Martin KJELDSEN
Chief III
Can you please double check? I'd be very interested to hear back. The watermark code is completely removed from the framework since 4.10.0 (The first release after ST acquisition) so it should definitely not be there. I think you're the first to report this, also, so i'm hoping you just have a pre-ST version.
Best regards,
Martin
