2020-11-16 3:45 AM
When Graphics Application is checked, a folders tree starting from TouchGFX, with files like GFX2.touchgfx, etc, is generated. It’s OK.
When the .ioc file becomes complicated (as the example I attach), it seems that TouchGFX is replaced by Src and all files are generated under Src, mixing them with main.c and the other files.
Could you fix this, please?
2020-11-17 5:36 AM
Can you elaborate on what you mean by "complicated" ? And in this case do you mean that "TouchGFX" files are being put under "Src" ?
/Martin
2020-11-17 11:10 PM
