2019-02-19 11:59 PM
Also, what position does the LTDC current position status register (LTDC_CPSR) return? Is it the position of the touch interrupt?
2019-02-21 3:04 AM
Answer if someone needs it: LTDC_CPSR register has no link with position of touch interrupt. In order to find touch position, you need to read the I2C memory of the touch screen pannel (http://www.newhavendisplay.com/app_notes/FT5x06_registers.pdf). Using peripheral I2C3 of uC. Default device adress is 0x70. Interesting registers for position are 0x3:0x6
