2021-03-30 3:46 PM
Thank you for helping.
How can I use English and Japanese?
Can you speak Japanese even if you run the simulator? The characters are garbled.
2021-03-31 4:29 AM
The issue you faced is due to the font you selected. You need to use a font that properly handles Japanese. I used for example IPA which is enclosed in the project attached.
/Romain
2021-03-30 7:40 PM
Hello Ebun.1,
Using Japanese and English should be pretty straight forward. Could you enclose your project so that I can have a quick look ?
/Alexandre
2021-03-30 7:53 PM
2021-03-31 4:29 AM
2021-03-31 3:47 PM
Hi Romain Dieleman
Thank you for adding it to the project.
Where should I touch? I understood about.
I cried for "麦�?ら�?�一味" . (^_^)
2021-04-01 6:34 AM
Sorry, I don't think we understand. You wrote "where should I touch?". Is your problem fixed now?
�?��?ん�?分�?�り�?��?�ん。「�?��?��?�触り�?��?��?��?�?�書�??�?��?��?�。今�?題�?��?��?��?��?��?�?
2021-04-01 3:18 PM
Hi Michael K
I was able to understand where to modify the display in Japanese.
No problem.
Thank you very much.
