2020-10-15 1:36 AM
Hi, I am developing code for a display on the STM32746G-Discovery.
Is it possible to display fonts without blending? (Not to have to erase the background beforehand)
If I use the DMA2D with memory to memory with blending, everything works as expected, However if I just use the Memory to Memory with PFC I am getting a filled rectangle.
It is like I can't pass information about the background colour; I understand the background fifo is not activated. Is it not possible because of that?
Thanks
2020-12-23 3:26 AM
Do you have combine alpha and input alpha set to your color?
2020-12-23 3:59 AM
Hi MKraus,
at th ened I gave up, I am erasing the whole screen and then drawing again everything.
I have an RGB565 layer, so there is no alpha channel there.
Thanks
