2019-02-04 3:23 AM
After having restarted TouchGFX designer and recompiled the code (without any errors), the couple interactions I had in my code to transition from one screen to another don't work anymore ? I've tried creating a new screen interaction and that one works just fine… Any idea what could be the cause and how to solve that issue ?
Thanks.
2019-02-05 6:00 AM
Thank you too. Sorry for the trouble! :)
2019-02-08 1:09 AM
@Guillaume Boulay :
you can configure a virtual function call and do the screen transition there.
The virtual function calls are not deleted in the current version of the designer.
2019-02-11 2:55 AM
Thanks for pointing that out, @AK.12.. That could indeed be used as a workaround until we can fix the underlying issue.
