2023-08-24 2:42 AM
I have buzzer on my custom PCB and I want to do that it beeps every time when button is clicked(but only button). Do I need to add buzzer function on every button interaction or maybe there is easier way.? Maybe someone knows how to achieve this?
2023-08-24 4:14 AM
You can create a custom interaction in TouchGFX that triggers a function in your code every time a button is clicked. This function would then activate the buzzer on your PCB. This way, you wouldn't need to add the buzzer function to every button interaction manually.
