STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Small example to use touch gestures.
Hello,I would really appreciate if you could provide a small example demonstrating how one can use touch gestures with TouchGFX. For instance, something showing how to display a rectangle upon doing a slide motion of a finger to the left and hiding i...
GMeur by Senior II
  • 648 Views
Compiling for STM32F769I Discovery
Hi. Following this document:https://touchgfx.zendesk.com/hc/en-us/articles/360020208091-Configuring-STM32F769I-DISCOand believe all the required changes have been made including applying comments to exclude the STM32 fonts as per this article. Howeve...
Mon2 by Senior III
  • 4312 Views
  • 16 replies
Question about STM32 TFT LCD Multi Layer
stm32f429i discovery board is undergoing various tests.There are many Layer-related functions in the BSP functionWhat is the difference between using 1 Layer and using Multi Layer when using LCD?Let me know if you have related videos or links.
DSEO by Associate II
  • 706 Views
Blank Screen when STEMWIN code generated from CubeMx
Hi,I am having this issue with STM32F469 and 769 Discovery boards. I am trying to create a project in CubeMx with ADC enabled and a STEMWIN Window created using GUIBuilder. When I try to generate this code and run it in SW4STM32, the Discover screen ...
AMoha.81 by Associate II
  • 2512 Views
