STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Configuring project for Keil rather than EWARM
Hello everybodyI am trying to configure a project for STM32F746-DISCO board with TouchGFX using CubeMx. A new project.However , the article for configuring the board at this link explains the modifications needed for linker script and modifying the p...
Resolved! How to print a Dot "." in Touchgfx?
I need to take input fractional values from user through UI built via TouchGFX.There is a separate Dot button on my UI keypad. But, I am not able to print it on the screen.Please help me for above problem. Just a short clue on what to use will also b...
kvkhekale by Associate II
  • 3054 Views
Help with an internal assert failure
I'm getting what looks like assert failures while running a TouchGFX project in Visual Studio.Its happening on two of my designed screens out of 12 so its likely something I've created but need a hint of where to look for the fault.It happens as soon...
View class inheritance
Hello,I am working now on project where screens have many things in common (slide menus, content etc). Is it possible to make a screen which will be the base class for further screens? Or I should make it a custom container?
maciek by Associate II
  • 1634 Views
STM32F769I-Disco with CubeMX + sw4stm32
Hello,I have tried to generate a simple GUI with touchgfx, CubeMX and sw4stm32 for stm32f769I-Disco. I used the guide "Configuring STM32F769I-Disco" from TouchGFX I have also read the Tutorial 10 from UM1718. But the GUI on the Screen does not look l...
DSI custom board problem with STM32F769BI MCU
Hello,I used STM32F769I-EVAL board as a design reference for custom board. However, I could not achieve correct operation of MB1166 LCD board which is connected via DSI. It works well on the evaluation board.When MCU tryies to display a picture, scre...
GSink by Associate II
  • 19573 Views
  • 16 replies
Interfacing custom touch controller... Advice needed
Hi colleagues,I'm facing some problems interfacing the I2C touch controller of my LCD dislay.The board's LCD works perfect using only MXCube for hardware configuration and Attolic to debug.Please give me advice what will be the best way to make a cu...
HBosh by Associate
  • 1127 Views
