STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
B-LCD40-DSI1 environmental parameters
I get the STM32F769IDiscovery board, the B-LCD40-DSI1 is the display daughter board.The B-LCD40-DSI1 data sheet without working temperature and humidity range, I'm not sure is this display board suitable for industry application, where can I find th...
Scroll List Manipulation
Hi there. I'm working to create a menu interface, it must works like a tree, and for that, i'm trying to use a scrolllist container. I'm already able to click on each item and already have a callback handler for this. The problem i'm trying to solve ...
problem with emwin
hi,i use stm32h743 and i use emwin functions ,but the functions of GUI not working i asked segger and they said maybe we need to update my version my version is: GUI_VERSION 54401do you have newer version ?
Hmizr.1 by Associate II
  • 5475 Views
  • 10 replies
New language initial text values
Hi,In the designer, when a new language is added there is an option to select the "Initial text values".Does those values are handled on the designer level or at the TouchGFX core level?Is there a way to update the initial language through API at run...
