STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
DCMI in JPEG mode DMA configuration?
Hello there.On my board I've setup DCMI to read some arbitrary data from ADC. I've planed to use JPEG mode to just capture all the raw data from ADC while HSYNC is in LOW state. There is my timing diagram:The thing is I do not get FRAME interrupt nor...
BStud.1 by Associate II
  • 1499 Views
How do I repeat a sequence of Interactions?
I have a screen where I want to repeat a sequence of widget moves once a button is pressed, and then stop it when another button is pressed. I have an Interaction triggered by the 1st button press that moves the widget down (MoveWidgetDown) and anot...
wired by Senior III
  • 880 Views
Resolved! Seems there is a name conflict between the "class LCD" (defined in LCD.hpp) and the #define LCD (in stm32wb55xx.h) when trying to build a project running touchGfx on a stm32WB55 mcu.
When building a freshly generated project using touchGfx on a stm32WB55 mcu, compiler complains about../Drivers/CMSIS/Device/ST/STM32WBxx/Include/stm32wb55xx.h:1084:29: error: expected identifier before '(' token 1084 | #define LCD (...
LVers.1 by Associate III
  • 1863 Views
Resolved! TouchGFX resize Keyboard
I am trying to use the CustomKeyboard provided in TouchGfx for a STM32F769 discovery board (https://www.st.com/en/evaluation-tools/32f769idiscovery.html).How can i resize the keyboard? Is this possible without resizing each key individually?The keybo...
JK.6 by Associate
  • 6124 Views
