STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Resolved! Download stall ...
After a good starting download stall ...Either with firefox or google under ubuntu 20, it is the touchGFX designer 450Mo.Regards.JP
Xynium by Associate III
  • 3217 Views
Touchgfx Touch Panel Routine
Hello Dear Engineers,I am looking for a standard touch handling routine using Touchgfx. The touch panel I am using is resistive which is handled by XPT2046 (TSC2046). The touch controller IC is controlled by SPI.The main problem I have been encounter...
Compile error
I always show this message when I compile.I tried to reinstall the TouchGFX 4.18.0 many times but it always same happened.I tried to run in Windows 11 and Windows 10, but it is not changed.I tried after removing the MS visual studio, but nothing chan...
How to swap little-endian to big-endian in TouchGFX?
Hi Community,I'm trying to connect STM32F412 with SPI LCD (ILI9341). And, I'm trying to run TouchGFX on this combination. The white and black color is correct. However, another colors are strange. I think that the endian is swapped. Might be, TouchGF...
KYama.1 by Associate III
  • 9455 Views
  • 14 replies
running TouchGFX_core from ITCM-RAM
hi everybody,happy new year.I try to run TouchGFX project on STM32H750 Disco board1.in first level I run my project through QSPI,so i had frame lost and cant reach 60 frame per sec2.in second level i run my code from external sdram,i gain more perfor...
Mmale.1 by Associate II
  • 5418 Views
