STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
X-CUBE-TOUCHGFX 4.19.1 is out
TouchGFX 4.19.1 is now online.Release notes (which can be found in the online documentation) are as follows:Bugfixes in TouchGFX Designer:Fixed missing color properties for Text Button Style on a Flex Button Widget.Fixed erroneous wildcard code gener...
Load PNG or ARGB8888 from a file to TouchGFX
Hello,I would like to know if it is possible to load a transparent format such as PNG or ARGB8888 from a file to TouchGFX from code?I have achieved to do this with BMP with the documentation but I need PNG.If I use a library such as libspng to decode...
SKham.2 by Associate II
  • 2721 Views
How to better interact with non-UI parts
I'm using an RTOS and have Touchgfx as a separate thread, but am having trouble with how to interact with the non-UI parts. Is there a good example for reference, preferably the source code, thank you
SLuo.2 by Associate III
  • 1985 Views
Is it possible to change the size of the scroll bar?
hello​Is it possible to change the size of the scroll bar?​​I'm using a "scrollable container".​In TouchGFX Designer, the color of the scrollerbar can be changed, but the size cannot be changed.​I would like to know how to change the size of the scro...
mSH.1 by Associate III
  • 1221 Views
