STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Hardware Button used Menu Options in Touchgfx .
Hai :I am using STM32H7 MCU custom board with Hardware Buttons. Set points can be changed by selecting the menu in the menu list and using the button.What the option used in the Touchgfx framework? I am trying change menu selection(Highlights). So us...
GMano.1 by Associate II
  • 2510 Views
Drop-down
Hello, I create drop-down used by slide menu but it isn't working how I want.When I click this dropdown it expands and background image goes to last position, like this :I want that my background picture be in first position like that:How can I achie...
heyo by Senior
  • 2644 Views
Resolved! TouchGFX DSI display, not coming out of standby mode.
Hello @Romain DIELEMAN​ , @Martin KJELDSEN​, I see that you have a lot of replies on the TouchGFX so I hope it's ok that I address you directly. I am running a low-power application with a DSI display and TouchGFX 13 (will update to latest eventuall...
KDubo by Associate II
  • 4394 Views
TouchGFX - switch between containers
Hi everyone, I am a beginner in TouchGFX.Right now I have created several containers with different buttons.My goal is as follows: When klicking a button of one container I want to change to another container.So far I have found only the possibility ...
ASteg.1 by Associate II
  • 3454 Views
Pass string to a function
I need to pass a 6 characters string to a function in a custom container, but the string is cut to 4 characters.The function is called in the screen where the container is, like this: container.function(str). If I pass a string smaller than 5 charact...
ALuiz.1 by Associate II
  • 1775 Views
