STM32 MCUs TouchGFX and GUI
Share your Custom Widgets!
Invalidate redraw part even if not visible
I am facing performance issue due probably to my way for invalidation on data update. I have widget inside container that are not visible. When I have a data change, I update the content of the widget and invalidate the textarea for example. But this...
SBACO by Associate III
  • 1048 Views
Resolved! STM32U585 DCMI+DMA problem
Hello, I am facing problems with DMA and DCMI . Since DMA has ability to generate multiple block transfers with single configuration, it means i can transfer image larger that 0xFFFF.So I writen code that would repat my DMA transfer for as much line ...
Linas L by Senior II
  • 8317 Views
Drawables
Hi, I created a list and I need set visible image when element of the list is clickedBut problem is that others drawables does not unselected when pressed one of the list elements. When I click on list element I call this functionvoid AddZone::ZoneSe...
heyo by Senior
  • 1409 Views
Resolved! I am not sure if this community provides support for my case but i will ask since the target microcontroller is a STM32F429IGT6. In short i bought a dev kit and a TFT lcd and i cannot make the lcd work.
Facts: I can program/debug very simple things so the problem is not there.It is my first attempt to work with STM32cubeIDE and i find it somewhat challenging.I have a STLinkV2 programmer/debugger that works fine.The dev kit i bought is: https://www.w...
