2026-04-24 5:27 AM
Hi Team,
Is there any framework or lib support available from ST for automation testing of TouchGFX based UI either on simulator or on actual device?
If anyone has any idea or workaround, then please share!
Thanks
2026-04-27 1:47 AM
2026-04-27 2:56 AM
@JohanAstrup Thanks for the update!
@Romain DIELEMAN I saw your old post for the same.
Can you share any data/steps for the same you did?
Thanks!
2026-04-28 12:52 AM
Hi Pritesh
Yes, we have been working on a UI test tool in Mjølner, like Johan said, which aims at fully automated tests that can even run on a CI server as part of the development process.
It is called Dvergr, and we tried to collect some technical information about it here: https://mjolner.dk/dvergr
Feel free to reach out if you would like to hear more about it :)
Kind regards
Bent Bisballe Nyeng
Mjølner Informatics A/S
