2021-07-27 12:04 AM
Hi all
My cipher text from STM32F429 crypto library(AES-CBC-256) is CTS(Ciphertext Stealing),but the cipher text can'e decrypt by openssl on my PC because the file length is not correct.
What can I do to solve it?
Thanx
2021-08-02 11:43 PM
Hi @YChen.5 ,
the usual way to round up the length of a plaintext to a size that is conformant with the cryptographic standard is to use a technique called padding. Look up what padding is recommended in your case. You may probably use zeroes to extend the content to required length.
J
